Hello Everyone,
I have a video file, a webm file specifically that throws this warning when converting to an mp4.
[matroska,webm @ 0x7f91f100e000] DTS discontinuity in stream 1: packet 4255 with DTS 478651, packet 4256 with DTS 564701
The file seems to convert just fine but is causing issues later on in the process when combining the MP4's into 1 video. The timestamps seem to be off, and people talk over each other.
I am having trouble getting a clear picture of what the warning message means and what implications this has when working with videos.
Thanks for your input.
This may happen when your source possibly has been cut and merged already. It may be solved by ignoring DTS timestamps or by forcing ffmpeg to rebuild timestamps while converting, instead of preserving them. Unfortunately I am not sure which of the many options is correct for your case...
How To Use ffmpeg to merge audio_only.webm with video_only.webm
By carlarogers in forum Video ConversionReplies: 3Last Post: 4th Aug 2020, 08:21 -
HLS With discontinuity stuck in buffer
By Alberto78 in forum ProgrammingReplies: 0Last Post: 15th Apr 2020, 02:58 -
mp4/mkv to webm (I see lots of posts going the other way but not TO webm)
By AshleyQuick in forum Video ConversionReplies: 9Last Post: 10th Aug 2018, 09:19 -
ffmpeg convert from mkv to mp4 [matroska,webm @ 0x1d06640] Read error at
By blurry in forum Video ConversionReplies: 6Last Post: 15th Jan 2018, 05:36 -
ffmpeg warning: timestamps are unset in a packet for stream 1
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 12th Mar 2017, 17:00
